    Jan 2006
    i have PHILIPS DVD 701 player, and i know you can update ur firmware , im stuck on how to create a CD using nero. I wanna know exactly what to do, ive read someone elses guide but its not clear.
    Can someone help me please???
  2. You shouldn't have to change anything, Nero's regular settings do fine.
    You don't need to update if things are working right for you.
    How to make an upgrade disc
    Write dvpxx.rom, dvpxxdv.rom and dvpxxEW.rom files onto a blank CD-R , using the following settings :
    File System CD-ROM ISO Level 2
    Mode 1/2/XA
    Character set ISO 9660
    Finalised, single session
    Write speed slow (e.g. 2x, 4x)
    Finalize the disc. (The application may do this automatically.)
    Jan 2006
    where do i get files from for upgrade?
    so how do i do change ISO level to 2? and what about that character set 9660???
    how do i change them
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    They are in the popup menu settings after you click burn. And unless you've already changed them from default, you don't need to change anything as stated by handyguy above.
    No offense, but if you can't even burn the upgrade disc, I would think twice about upgrading your firmware. If you do it incorrectly, the player will NOT work and it is NOT covered under warranty.
    Google is your Friend
